We’re migrating from Ubuntu 14.04 to 16.04, and we can’t seem to get the Astra Pro running.
We have no problem with the regular Astra, just the Pro.
I have downloaded the SDK from here: http://www.orbbec3d.net/Tools_SDK_OpenNI/2-Linux.zip
Have run install.sh as root, and compiled the SimpleViewer example, then I run it and get the following:
~/OpenNI-Linux-x64-2.3/Samples/SimpleViewer/Bin/x64-Release# whoami
root
~/OpenNI-Linux-x64-2.3/Samples/SimpleViewer/Bin/x64-Release# ./SimpleViewer
After initialization:
SimpleViewer: Device open failed:
DeviceOpen using default: no devices found
This is the output of lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 2b04:c006
Bus 001 Device 004: ID 2bc5:0501
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
No other applications are using or attempting to use it.
