I’m having the same issue, and here is the log contents:
2016-06-13 15:55:36,369 WARN [context] Hold on to yer butts
2016-06-13 15:55:36,369 INFO [context] configuration path: /home/konneker/code/astra/build/bin/…/lib/astra.toml
2016-06-13 15:55:36,369 INFO [context] log file path: astra.log
2016-06-13 15:55:36,369 INFO [context] plugin path: /home/konneker/code/astra/build/bin/…/lib/Plugins/
2016-06-13 15:55:36,370 TRACE [plugin_manager] [void astra::plugin_manager::load_plugins(std::string)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:35] load plugins
2016-06-13 15:55:36,370 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:96] try_load_plugin /home/konneker/code/astra/build/bin/…/lib/Plugins/libopenni_sensor.so
2016-06-13 15:55:36,371 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:111] try_load_plugin valid plugin
2016-06-13 15:55:36,372 INFO [orbbec.ni.oni_adapter_plugin] Initializing OpenNI v2.2.0.33
2016-06-13 15:55:36,379 INFO [orbbec.ni.oni_adapter_plugin] Initialized OpenNI v2.2.0.33
2016-06-13 15:55:36,379 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:113] try_load_plugin initialized plugin
2016-06-13 15:55:36,379 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:96] try_load_plugin /home/konneker/code/astra/build/bin/…/lib/Plugins/liborbbec_hand.so
2016-06-13 15:55:36,382 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:111] try_load_plugin valid plugin
2016-06-13 15:55:36,382 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:113] try_load_plugin initialized plugin
2016-06-13 15:55:36,382 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:96] try_load_plugin /home/konneker/code/astra/build/bin/…/lib/Plugins/liborbbec_xs.so
2016-06-13 15:55:36,383 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:111] try_load_plugin valid plugin
2016-06-13 15:55:36,383 INFO [astra.xs.plugin] Initializing xs plugin
2016-06-13 15:55:36,384 TRACE [plugin_manager] [void astra::plugin_manager::try_load_plugin(const string&)] [/home/konneker/code/astra/src/astra_core/astra_plugin_manager.cpp:113] try_load_plugin initialized plugin
2016-06-13 15:55:36,928 INFO [context] client opening streamset: device/default
2016-06-13 15:55:36,929 INFO [streamset_catalog] default uri provided.
2016-06-13 15:55:36,929 TRACE [astra.streamset] [astra::streamset_connection* astra::streamset::add_new_connection()] [/home/konneker/code/astra/src/astra_core/astra_streamset.cpp:118] new connection to device/sensor0
2016-06-13 15:55:36,929 INFO [astra.streamset] connecting to (7,0) on device/sensor0
2016-06-13 15:55:36,930 TRACE [astra.streamset] [astra::stream_connection* astra::streamset::create_stream_connection(const astra_stream_desc_t&)] [/home/konneker/code/astra/src/astra_core/astra_streamset.cpp:40] registering orphan stream of type (7,0) on device/sensor0
2016-06-13 15:55:36,930 DEBUG [astra.streamset] registering stream (7, 0) on device/sensor0
2016-06-13 15:55:36,930 DEBUG [astra.stream_connection] 0x25fe4e0 starting (7, 0)
2016-06-13 15:55:36,930 INFO [astra.streamset] connecting to (1,0) on device/sensor0
2016-06-13 15:55:36,930 TRACE [astra.streamset] [astra::stream_connection* astra::streamset::create_stream_connection(const astra_stream_desc_t&)] [/home/konneker/code/astra/src/astra_core/astra_streamset.cpp:40] registering orphan stream of type (1,0) on device/sensor0
2016-06-13 15:55:36,930 DEBUG [astra.streamset] registering stream (1, 0) on device/sensor0
2016-06-13 15:55:36,930 DEBUG [astra.stream_connection] 0x2600d00 starting (1, 0)
2016-06-13 15:56:42,487 INFO [orbbec.ni.oni_adapter_plugin] shutting down openni
2016-06-13 15:56:42,705 INFO [astra.xs.plugin] Terminated xs plugin
2016-06-13 15:56:42,705 TRACE [streamset_connection] [virtual astra::streamset_connection::~streamset_connection()] [/home/konneker/code/astra/src/astra_core/astra_streamset_connection.hpp:40] destroying streamset_connection: 0x258a600
2016-06-13 15:56:42,705 TRACE [astra.stream_reader] [virtual astra::stream_reader::~stream_reader()] [/home/konneker/code/astra/src/astra_core/astra_stream_reader.cpp:38] destroying reader: 0x25fe2f0
2016-06-13 15:56:42,705 TRACE [astra.streamset] [bool astra::streamset::destroy_stream_connection(astra::stream_connection*)] [/home/konneker/code/astra/src/astra_core/astra_streamset.cpp:59] destroying 0x2600d00 on device/sensor0
2016-06-13 15:56:42,705 TRACE [astra.streamset] [bool astra::streamset::destroy_stream_connection(astra::stream_connection*)] [/home/konneker/code/astra/src/astra_core/astra_streamset.cpp:67] removing unused/unavailable stream 0x2600ca0 on device/sensor0
2016-06-13 15:56:42,705 TRACE [astra.streamset] [bool astra::streamset::destroy_stream_connection(astra::stream_connection*)] [/home/konneker/code/astra/src/astra_core/astra_streamset.cpp:59] destroying 0x25fe4e0 on device/sensor0
2016-06-13 15:56:42,705 TRACE [astra.streamset] [bool astra::streamset::destroy_stream_connection(astra::stream_connection*)] [/home/konneker/code/astra/src/astra_core/astra_streamset.cpp:67] removing unused/unavailable stream 0x25fe430 on device/sensor0
2016-06-13 15:56:42,705 INFO [context] Astra terminated.
2016-06-13 15:56:42,706 WARN [context] attempt to destroy a non-existent reader: 0x25fe2f0
Any insights?
