Hi! I am using Femto Bolt on Ubuntu 20.02 on a Raspberry Pi 4.
I was able to compile everything and get the color viewer working. However, when I tried to run the Depth Viewer(cpp), the following error message shows:
[MSDEConverterDevice.cpp:67] Depth engine got nvram data size:492088
[MSDEConverterDevice.cpp:94] Depth engine create and initialize failed, retCode:204.
I am having problems using Femto Bolt on my Ubuntu machine. I have installed the pyorbbecsdk according to the guidelines, but I receive the error message shown below when running the …/examples/depth_viewer.py example. What can be the reason?
[info][3906068][MSDEConverterDevice.cpp:94] use dynlib load depthengine lib…
[error][3906068][MSDEConverterDevice.cpp:101] Depth engine create and initialize failed,retCode:204
Thank you for your response. Do you know if Orbbec has tested Femto Bolt on the NVIDIA® Jetson Orin™ Nano Developer Kit? Is there anything else( configurations etc…) that i need to pay attention to when using the Nano board to develop.
