Hi, I am using Femto Bolt with Debian on Raspberry Pi 5 (ARM64).
The color viewer is good but the depth viewer cannot open.
[info][20804][VideoSensor.cpp:646] start OB_SENSOR_DEPTH stream with profile: {type: OB_STREAM_DEPTH, format: OB_FORMAT_Y16, width: 640, height: 576, fps: 30}, Backend Format: OB_FORMAT_Y16
[info][20804][MSDEConverterDevice.cpp:549] Start real profile,width:7680 height:434
[info][20827][MSDEConverterDevice.cpp:67] Depth engine got nvram data size:490160
[info][20827][MSDEConverterDevice.cpp:94] use dynlib load depthengine lib…
[error][20827][MSDEConverterDevice.cpp:101] Depth engine create and initialize failed,retCode:204
This is similar to Femto Bolt on Raspberry Pi4 ubuntu 20.02 Depth Engine Create and initialize failed, retCode:206
