The new version includes NET/C# wrapper, can not find any example or instructions to use it in visual studio.
Hi, im looking for the same code examples.
I cannot find it.
Hello @shmlex and @victorsbd,
Here you can find sample code:
Some notes about using of C# wrapper:
Use binaries from SDK for VS 2015. In other case youāll have issues. See Issues with initialization and deinitialization of C# wrapper -- SOLVED for details. In the above sample project all required binaries are already included.
Call
Astra.Context.Initialize()to initialize library before use. And donāt forget to callAstra.Context.Terminate()before exit from application (without this call application will crash on exit). SeeApp.xaml.csin the sample code. -
To start working with sensor, call
Astra.StreamSet.Open(). If you want to work with multiple sensors, then callAstra.StreamSet.Open("device/sensorN"), where N is zero-based index of sensor. SeeMainWindow.xaml.csin the sample code. -
Then, using this opened
streamSetcreate stream reader by callingstreamSet.CreateReader(). See constructor inSensorViewModel.csin the sample code. -
To work with depth stream, use
streamReader.GetStream<Astra.DepthStream>(). To work with color stream, usestreamReader.GetStream<Astra.ColorStream>(). Etc. See constructor inSensorViewModel.csfile in the sample code. -
Set required mode for depth (and/or) color stream using
AvailableModesproperty andSetMode(mode)method. SeeSetDepthMode()andTrySetColorMode()methods inSensorViewModel.csfile in the sample code. -
Be aware that not all modes returned by
AvailableModesare actually supported! This issue was reported here: Can't get 60 fps - #3 by andrew -
To start streaming of data call
Start()method for appropriate steam. -
To receive frames from stream(s) you have to organize loop (it is better to do it in some background thread to keep responsibility of your UI). In this loop call
streamReader.TryOpenFrame()and then useout frameto access data. Donāt forget to freeframeby callingframe.Dispose()or by usingusing (frame)clause. SeeBackgroundProcessingLoop()method inSensorViewModel.csfile in the sample code. -
Alternatively, you can call
Astra.Context.Update()method in this loop and subscribe tostreamReader.FrameReadyevent. But it is not so convenient in case of working with multiple sensors. -
Donāt forget to dispose
streamSetandstreamReaderwhen you stop working with sensor. SeeDispose()method inSensorViewModel.csfile in the sample code.
Have fun!
Thanks for the sample code! Iām trying to make a stand-alone camera class that will deliver OpenCV Mat objects, but Iām getting an error when I try to set the stream mode: every time I try to access depthStream.AvailableModes I get an āAstra.AstraException: astra_imagestream_request_modes: Invalid Operationā error. (My code to set the mode is copied and pasted from your sample code.)
Iāve got copies of all of the relevant DLLs (same versions as your example project), and Iām initializing the Astra context in my application startup event. Have you run into this error before? If so, what did you do to fix it?
Hello @chrisib,
This error is very general. It erases in case of any troubles inside Astra SDK. To have additional information, you can run your application under Debugger (F5 in MS VS) and check content of Output window in Visual Studio. It should contain log messages from Astra SDK.
And, please, make sure that you donāt have AstraDotNet.dll file in your output directory (Debug or Release). This file must be only in subdirectories Astra\amd64 and Astra\x86. If you have this file at the same level as your main executable file, then please select reference to AstraDotNet assembly in Project Explorer inside Visual Studio and set Copy Local = False in Properties panel.
Also, have you tried samples from bin directory of Astra SDK? Do they work for you?
The sample programs run fine, and I can compile and run your WPF demo just fine. So obviously Iām doing something wrong, but I have no idea what.
In my output directory (at the root level) I have the 64-bit astra.dll, astra_core.dll, astra_core_api.dll, and AstraDotNet.dll, along with my main executable. My build target is x86_64, so itās not an architecture mismatch error.
Hereās the output that gets logged to the console:
2018-01-03 10:12:41,094 WARN [context] Hold on to yer butts 2018-01-03 10:12:41,094 INFO [context] configuration path: E:\code\Prism3\VisionServer\bin\x64\Debug\astra.toml 2018-01-03 10:12:41,094 INFO [context] log file path: astra.log 2018-01-03 10:12:41,094 INFO [context] astra_core library version: v2.0.7-beta-5f803a5e24 API Level: 1 2018-01-03 10:12:41,094 INFO [context] astra_core_api library version: v2.0.7-beta-5f803a5e24 API Level: 1 2018-01-03 10:12:41,094 INFO [context] plugin search paths E:\code\Prism3\VisionServer\bin\x64\Debug\Plugins\;E:\code\Prism3\VisionServer\bin\x64\Debug\ 2018-01-03 10:12:41,105 WARN [context] Astra found no plugins. Is there a Plugins folder? Is the working directory correct? oopsoopsoopsoopsoopsoopsoopsoops2018-01-03 10:12:43,158 INFO [context] client opening streamset: device/sensor0 2018-01-03 10:12:43,164 INFO [astra.streamset] connecting to (1,0) on device/sensor0 Exception thrown: 'Astra.AstraException' in AstraDotNet.dll An unhandled exception of type 'Astra.AstraException' occurred in AstraDotNet.dll astra_imagestream_request_modes: Invalid Operation
It explains a lot. And you have hint in log:
The thing is that Astra SDK requires some plugins to operate with sensor. Please, copy all required dlls along with astra.dll, astra_core.dll, astra_core_api.dll, and AstraDotNet.dll.
Minimal set of required libraries is the following:
- astra.dll
- astra_core.dll
- astra_core_api.dll
- AstraDotNet.dll
- OpenNI.ini
- OpenNI2.dll
- OpenNI2
- Drivers
- orbbec.dll
- orbbec.ini
- Drivers
- Plugins
- openni_sensor.dll
I tried adding the plugins folder and it resulted in the same error. I then added the whole Astra directory from your example, along with the AssemblyResolver class you made, and Iām getting the same problem.
My application also uses OpenNI2 loaded through NuGet, so perhaps thereās a version incompatibility with the OpenNI dlls?
You also have to add OpenNI2 directory. Also, please check log in Output window for new details about error.
Most likely, you didnāt remove AstraDotNet.dll assembly from directory with your exe-file. As a result, AssemblyResolver donāt work, because AstraDotNet.dll can be loaded from directory with exe-file by default assembly loading mechanism.
I donāt know for sure. You can compare versions of dll-s from Astra SDK bin directory and from NuGet package.
I did definitely remove the root-level libraries when I added the Astra directory.
Part of my problem is that Iām trying to add a new camera class to an existing (massive) application, so the dependencies are giving me a headache. Iāve made a new, really streamlined program that, in theory, should just grab depth frames from the camera and turn them into OpenCV Mat objects.
It compiles just fine, but on startup Iām getting āSystem.DllNotFoundException: 'Unable to load DLL āastra_coreā: The specified module could not be found,ā even though I have the name resolver initialized, and the DLL is definitely located in the Astra directory in the output folder.
The code is here: Dropbox - File Deleted
I didnāt include the NuGet packages, so youāll need to restore them through Visual Studio before it will compile.
Any insight you can provide would be greatly appreciated. My big application is currently using OpenNI via the NuGet wrapper to control the Astra, but Iām hoping to replace that with the new .NET wrapper to cut down on the third-party dependencies, but the fact that I canāt even get a simple demo application working is making me feel like a bit of an idiot right nowā¦
This application donāt work because of bug in my AstraDotNetAssemblyResolver: line 55
var path = Path.Combine(appDomain.BaseDirectory, DirName, Environment.Is64BitProcess ? SubDir64bit : SubDir64bit);
should be changed to
var path = Path.Combine(appDomain.BaseDirectory, DirName, Environment.Is64BitProcess ? SubDir64bit : SubDir32bit);
The thing is that your application actually runs in 32-bit mode due to ticked Prefer 32-bit checkbox in Build settings of AstraSdkTest project. And as you can see there was a miss-print in my code that affected applications in 32-bit mode.
ADDITION: Also, please set Copy Local = False for reference to AstraDotNet.
ZIP-archive with fixed application:
https://drive.google.com/open?id=1F0p0vq4TmeUdN0MVFO_bfd5J6csjj0m
Thank-you! I had completely forgotten about the āCopy Localā option in Visual Studioās references. Not the first time thatās tripped me up, and probably not the last unfortunately. And I definitely hadnāt noticed the 32/64 bit copy-and-paste mistake. Now that my OpenCV breakpoint seems to be working I can go back and see if I can get the full application working.
Have you had a chance to play around with the body-tracking part of the API yet? Itās further down on my to-do list. But with the recent announcement that the PC adapter kit for the Kinect is not available in a lot of places anymore, the Astra is quickly looking like the go-to sensor with skeletal tracking support.
Two questions:
Q1: Iāve overlooked the bibigone/AstraDotNet demo, in the external / Plugins directory, the OrbbecBodyTracking DLL is missing⦠that means the C# wrapper does not support body tracking? or if I copy OrbbecBodyTracking.dll to the plugins directory, I would āautomaticallyā be able to query for body streams?
Q2: What about packaging everything in a Nuget package?
This question is answered in readme (AstraDotNetDemo/readme.md at master Ā· bibigone/AstraDotNetDemo Ā· GitHub):
Notes:
- Directory
externals\AstraSDK.bindoes not contain plugin for body tracking (to save space). This why if youāre going to useBodyStream, then you have to addOrbbecBodyTracking.dlldll-s toPluginssubdirs (both, x86 and amd64 versions) and add them to projectAstraTestWpfas links with the following properties:
- Build Action = Content
- Copy to Output Directory = Copy if newer
I suppose, this question should be redirected to authors of SDK and C# wrapper.
Because of many questions about body tracking, Iād like to add the following:
Body tracking is included in v2.0.7. And it is supported by C# wrapper. But in my sample I excluded body tracking plugin from project because this pluginās DLLs are very large (more than 45 MB for each architecture). I described this fact in readme:
Notes:
- Directory
How to use body tracking API:
- get
BodyStreamfromstreamReaderjust like you getDepthStreamandColorStream:
// here, streamReader is object of StreamReader
var bodyStream = streamReader.GetStream<BodyStream>(); - call
bodyStream.Start()among withdepthStream.Start()to start body tracking - when you processing received frame, you can ask
BodyFrameto access current body data (again, just like your accessDepthFrame):
// here, frame is object of ReaderFrame received from Astra SDK
var bodyFrame = frame.GetFrame<BodyFrame>(); - then you can access the following information:
bodyFrame.FloorInfo- information about floor;bodyFrame.BodyMask- which pixels on depth map belong to which body (map of indices)var bodies = new Body[6]; bodyFrame.CopyBodyData(ref bodies);- information about bodies (Astra SDK can track up to 6 bodies simultaneously)
- for each body you have several properties like:
Status- NotTracking/Lost/TrackingStarted/TrackingJoints- array of body joints
- Each joint, in turn, has its own properties:
Type- joint type (Head, ShoulderSpine, etc.)
Status- NotTracked/LowConfidence/TrackedDepthPosition- position of joint on depth map (use this property to draw skeleton over depth image)WorldPosition- 3D position of joint (use it for 3D visualization and analysis)Orientation- matrix of bone rotation in 3D
@andrew after the definition and start of bodyStream the frame could not open.
Look at BackgroundProcessingLoop(),
streamReader.TryOpenFrame(10, out var frame) always returns false.
Iāve tried to rise the response time, change streaming modes, eliminate colorStream ⦠but nothings helps
Any advice?
Hello @shmlex,
Did you add OrbbecBodyTracking.dll to Plugins subfolder? Do you have this DLL in appropriate subdirectory of output directory? If yes, then please run your application under debugger (F5 key in Visual Studio) and check content of Output Window in Visual Studio. It should contain log messages from Astra SDK. They can help in understanding of your issue.
Hi Andrew,
I have the same problem. I canāt find OrbbecBodyTracking.dll anywhere. Itās not in your sample project. And itās not in Astra V2.0.7 SDK either. Do you know where I can download it from?
Thanks again!
Iāve just updated sample to include body tracking:
