( “New users” are limited to only three replies per topic? So I’m editing this previous reply instead…)
OK, stupid user trick here. I have Astra Pros. I had looked at the box and label and just seen Astra, not noticing “Pro” was on another line. Ooops!
Sorry for the confusion!
</pointless edit>
The depthviewer log: (This works great.)
2015-12-30 19:46:37,733 WARN [context] Hold on to yer butts
2015-12-30 19:46:37,737 INFO [context] configuration path: D:\Heliotrope\SW\Orbbec\AstraSDK-0.4.0-win64\AstraSDK-0.4.0-20151014T193139Z-win64\bin\astra.toml
2015-12-30 19:46:37,745 INFO [context] log file path: astra.log
2015-12-30 19:46:37,748 INFO [context] plugin path: D:\Heliotrope\SW\Orbbec\AstraSDK-0.4.0-win64\AstraSDK-0.4.0-20151014T193139Z-win64\bin\Plugins
2015-12-30 19:46:37,757 INFO [orbbec.ni.oni_adapter_plugin] Initializing OpenNI v2.3.0.15
2015-12-30 19:46:38,281 INFO [orbbec.ni.oni_adapter_plugin] device connected: \?\usb#vid_2bc5&pid_0403&mi_00#7&e302640&0&0000#{c3b5f022-5a42-1980-1909-ea72095601b1}
2015-12-30 19:46:38,289 INFO [astra.plugin_service] creating streamset: device/sensor0 393a70
2015-12-30 19:46:38,294 INFO [orbbec.ni.device_streamset] opening device: \?\usb#vid_2bc5&pid_0403&mi_00#7&e302640&0&0000#{c3b5f022-5a42-1980-1909-ea72095601b1}
2015-12-30 19:46:38,464 INFO [orbbec.ni.device_streamset] opened device: \?\usb#vid_2bc5&pid_0403&mi_00#7&e302640&0&0000#{c3b5f022-5a42-1980-1909-ea72095601b1}
2015-12-30 19:46:38,472 INFO [astra.plugins.Stream] creating a 2, 0
2015-12-30 19:46:38,475 INFO [astra.plugin_service] created stream – handle 000000001B0DE4D0 type: 2
2015-12-30 19:46:38,480 INFO [orbbec.ni.devicestream] creating oni stream of type: 2
2015-12-30 19:46:38,489 INFO [orbbec.ni.devicestream] created oni stream of type: 2
2015-12-30 19:46:38,494 INFO [orbbec.ni.devicestream] stream type 2 supports modes:
2015-12-30 19:46:38,499 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 30 pf: 200
2015-12-30 19:46:38,504 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 30 pf: 201
2015-12-30 19:46:38,509 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 30 pf: 205
2015-12-30 19:46:38,514 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 15 pf: 200
2015-12-30 19:46:38,518 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 15 pf: 201
2015-12-30 19:46:38,523 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 15 pf: 205
2015-12-30 19:46:38,528 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 60 pf: 200
2015-12-30 19:46:38,533 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 60 pf: 201
2015-12-30 19:46:38,538 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 60 pf: 205
2015-12-30 19:46:38,543 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 30 pf: 200
2015-12-30 19:46:38,548 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 30 pf: 201
2015-12-30 19:46:38,553 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 30 pf: 205
2015-12-30 19:46:38,557 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 15 pf: 200
2015-12-30 19:46:38,562 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 15 pf: 201
2015-12-30 19:46:38,567 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 15 pf: 205
2015-12-30 19:46:38,572 INFO [orbbec.ni.devicestream] - w: 1280 h: 1024 fps: 30 pf: 200
2015-12-30 19:46:38,577 INFO [orbbec.ni.devicestream] - w: 1280 h: 1024 fps: 30 pf: 202
2015-12-30 19:46:38,582 INFO [orbbec.ni.devicestream] - w: 1280 h: 1024 fps: 30 pf: 201
2015-12-30 19:46:38,587 INFO [orbbec.ni.devicestream] - w: 1280 h: 1024 fps: 30 pf: 205
2015-12-30 19:46:38,593 INFO [orbbec.ni.devicestream] - w: 1280 h: 720 fps: 30 pf: 200
2015-12-30 19:46:38,598 INFO [orbbec.ni.devicestream] - w: 1280 h: 720 fps: 30 pf: 202
2015-12-30 19:46:38,603 INFO [orbbec.ni.devicestream] - w: 1280 h: 960 fps: 30 pf: 200
2015-12-30 19:46:38,607 INFO [orbbec.ni.devicestream] - w: 1280 h: 960 fps: 30 pf: 202
2015-12-30 19:46:38,612 INFO [orbbec.ni.devicestream] bin swap: 640x480x3 len: 921600
2015-12-30 19:46:38,619 INFO [astra.plugin_service] creating bin – handle: 392670 stream: 1b0de4d0 type: 2 size: 921628
2015-12-30 19:46:38,625 INFO [astra.plugins.Stream] creating a 1, 0
2015-12-30 19:46:38,629 INFO [astra.plugin_service] created stream – handle 000000001B0DEA70 type: 1
2015-12-30 19:46:38,634 INFO [orbbec.ni.devicestream] creating oni stream of type: 1
2015-12-30 19:46:38,663 INFO [orbbec.ni.devicestream] created oni stream of type: 1
2015-12-30 19:46:38,669 INFO [orbbec.ni.devicestream] stream type 1 supports modes:
2015-12-30 19:46:38,674 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 30 pf: 100
2015-12-30 19:46:38,679 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 30 pf: 101
2015-12-30 19:46:38,684 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 60 pf: 100
2015-12-30 19:46:38,689 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 60 pf: 101
2015-12-30 19:46:38,694 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 30 pf: 100
2015-12-30 19:46:38,698 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 30 pf: 101
2015-12-30 19:46:38,703 INFO [orbbec.ni.devicestream] - w: 1280 h: 1024 fps: 5 pf: 100
2015-12-30 19:46:38,708 INFO [orbbec.ni.devicestream] - w: 1280 h: 1024 fps: 5 pf: 101
2015-12-30 19:46:38,713 INFO [orbbec.ni.devicestream] - w: 160 h: 120 fps: 30 pf: 100
2015-12-30 19:46:38,718 INFO [orbbec.ni.devicestream] - w: 160 h: 120 fps: 30 pf: 101
2015-12-30 19:46:38,722 INFO [orbbec.ni.devicestream] bin swap: 640x480x2 len: 614400
2015-12-30 19:46:38,728 INFO [astra.plugin_service] creating bin – handle: 3927f0 stream: 1b0dea70 type: 1 size: 614428
2015-12-30 19:46:38,735 INFO [astra.plugins.Stream] creating a 3, 0
2015-12-30 19:46:38,738 INFO [astra.plugin_service] created stream – handle 000000001C582A30 type: 3
2015-12-30 19:46:38,745 INFO [orbbec.ni.devicestream] creating oni stream of type: 3
2015-12-30 19:46:38,754 INFO [orbbec.ni.devicestream] created oni stream of type: 3
2015-12-30 19:46:38,790 INFO [orbbec.ni.devicestream] stream type 3 supports modes:
2015-12-30 19:46:38,796 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 30 pf: 203
2015-12-30 19:46:38,802 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 30 pf: 200
2015-12-30 19:46:38,808 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 60 pf: 203
2015-12-30 19:46:38,815 INFO [orbbec.ni.devicestream] - w: 320 h: 240 fps: 60 pf: 200
2015-12-30 19:46:38,820 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 30 pf: 203
2015-12-30 19:46:38,827 INFO [orbbec.ni.devicestream] - w: 640 h: 480 fps: 30 pf: 200
2015-12-30 19:46:38,832 INFO [orbbec.ni.devicestream] - w: 1280 h: 1024 fps: 30 pf: 203
2015-12-30 19:46:38,837 INFO [orbbec.ni.devicestream] - w: 1280 h: 1024 fps: 30 pf: 200
2015-12-30 19:46:38,842 INFO [orbbec.ni.devicestream] bin swap: 320x240x2 len: 153600
2015-12-30 19:46:38,847 INFO [astra.plugin_service] creating bin – handle: 3928f0 stream: 1c582a30 type: 3 size: 153628
2015-12-30 19:46:38,854 INFO [orbbec.ni.oni_adapter_plugin] Initialized OpenNI v2.3.0.15
2015-12-30 19:46:38,862 INFO [context] client opening streamset: device/sensor0
2015-12-30 19:46:38,866 INFO [astra.streamset] connecting to (1,0) on device/sensor0
2015-12-30 19:46:38,873 INFO [astra.plugins.Stream] adding connection
2015-12-30 19:46:38,877 INFO [astra.plugin_service] linking connection to bin – stream: 1b0dea70 type: 1 conn: 392df8 bin: 3927f0
2015-12-30 19:46:38,886 INFO [HandTracker] creating hand streams
2015-12-30 19:46:38,890 INFO [astra.plugins.Stream] creating a 4, 0
2015-12-30 19:46:38,893 INFO [astra.plugin_service] created stream – handle 000000001C582DF0 type: 4
2015-12-30 19:46:38,899 INFO [astra.plugin_service] creating bin – handle: 392e70 stream: 1c582df0 type: 4 size: 448
2015-12-30 19:46:38,906 INFO [astra.plugins.Stream] creating a 3001, 0
2015-12-30 19:46:38,911 INFO [astra.plugin_service] created stream – handle 000000001C582EB0 type: 3001
2015-12-30 19:46:38,918 INFO [astra.plugin_service] creating bin – handle: 392ef0 stream: 1c582eb0 type: 3001 size: 57656
2015-12-30 19:46:38,925 INFO [orbbec.ni.devicestream] turn on stream 1
2015-12-30 19:46:38,929 INFO [orbbec.ni.devicestream] starting oni stream of type: 1
2015-12-30 19:46:38,972 INFO [orbbec.ni.devicestream] started oni stream of type: 1
2015-12-30 19:46:38,977 INFO [orbbec.ni.device_streamset] adding stream type 1 to active streams
2015-12-30 19:46:38,984 INFO [astra.streamset] connecting to (7,0) on device/sensor0
2015-12-30 19:46:38,992 INFO [astra.plugins.xs.XSPlugin] Initializing XS plugin
2015-12-30 19:46:38,996 INFO [astra.plugins.xs.XSPlugin] creating point processor
2015-12-30 19:46:39,002 INFO [context] client opening streamset: device/sensor0
2015-12-30 19:46:39,008 INFO [astra.streamset] connecting to (1,0) on device/sensor0
2015-12-30 19:46:39,014 INFO [astra.plugins.Stream] adding connection
2015-12-30 19:46:39,018 INFO [astra.plugin_service] linking connection to bin – stream: 1b0dea70 type: 1 conn: 392ff8 bin: 3927f0
2015-12-30 19:46:39,026 INFO [orbbec.ni.devicestream] turn on stream 1
2015-12-30 19:46:39,152 INFO [context] client opening streamset: device/default
2015-12-30 19:46:39,155 INFO [streamset_catalog] default uri provided.
2015-12-30 19:46:39,158 INFO [astra.streamset] connecting to (7,0) on device/sensor0
2015-12-30 19:46:39,161 INFO [astra.streamset] connecting to (1,0) on device/sensor0
2015-12-30 19:46:39,165 INFO [astra.plugins.Stream] adding connection
2015-12-30 19:46:39,167 INFO [astra.plugin_service] linking connection to bin – stream: 1b0dea70 type: 1 conn: 1d31b468 bin: 3927f0
2015-12-30 19:46:39,173 INFO [orbbec.ni.devicestream] turn on stream 1
2015-12-30 19:46:39,180 INFO [PointProcessor] creating point stream
2015-12-30 19:46:39,182 INFO [astra.plugins.Stream] creating a 7, 0
2015-12-30 19:46:39,185 INFO [astra.plugin_service] created stream – handle 000000001C582FD0 type: 7
2015-12-30 19:46:39,198 INFO [astra.plugin_service] creating bin – handle: 1d31b760 stream: 1c582fd0 type: 7 size: 3686456
2015-12-30 19:46:39,203 INFO [astra.plugins.Stream] adding connection
2015-12-30 19:46:39,205 INFO [astra.plugin_service] linking connection to bin – stream: 1c582fd0 type: 7 conn: 392f78 bin: 1d31b760
2015-12-30 19:46:39,211 INFO [astra.plugins.Stream] adding connection
2015-12-30 19:46:39,213 INFO [astra.plugin_service] linking connection to bin – stream: 1c582fd0 type: 7 conn: 1d31b3e8 bin: 1d31b760
2015-12-30 19:46:39,219 INFO [PointProcessor] created point stream
2015-12-30 19:46:47,925 INFO [orbbec.ni.devicestream] destroying oni stream of type: 2
2015-12-30 19:46:47,942 INFO [astra.plugin_service] destroying bin – 392670 stream: 1b0de4d0 type: 2 size: 921628
2015-12-30 19:46:47,949 INFO [astra.plugin_service] destroying stream – handle: 1b0de4d0 type: 2
2015-12-30 19:46:47,956 INFO [orbbec.ni.devicestream] stopping oni stream of type: 1
2015-12-30 19:46:48,939 INFO [orbbec.ni.devicestream] stopped oni stream of type: 1
2015-12-30 19:46:48,944 INFO [orbbec.ni.device_streamset] removing stream type 1 from active streams
2015-12-30 19:46:48,949 INFO [orbbec.ni.devicestream] destroying oni stream of type: 1
2015-12-30 19:46:48,953 INFO [astra.plugin_service] destroying bin – 3927f0 stream: 1b0dea70 type: 1 size: 614428
2015-12-30 19:46:48,959 INFO [astra.plugin_service] destroying stream – handle: 1b0dea70 type: 1
2015-12-30 19:46:48,963 INFO [astra.plugin_service] destroying bin – 392e70 stream: 1c582df0 type: 4 size: 448
2015-12-30 19:46:48,968 INFO [astra.plugin_service] destroying stream – handle: 1c582df0 type: 4
2015-12-30 19:46:48,973 INFO [astra.plugin_service] destroying bin – 392ef0 stream: 1c582eb0 type: 3001 size: 57656
2015-12-30 19:46:48,980 INFO [astra.plugin_service] destroying stream – handle: 1c582eb0 type: 3001
2015-12-30 19:46:48,988 INFO [astra.plugins.Stream] removing connection
2015-12-30 19:46:48,992 INFO [astra.plugin_service] unlinking connection to bin – stream: 1c582fd0 type: 7 conn: 392f78
2015-12-30 19:46:49,000 INFO [astra.plugin_service] destroying bin – 1d31b760 stream: 1c582fd0 type: 7 size: 3686456
2015-12-30 19:46:49,008 INFO [astra.plugin_service] destroying stream – handle: 1c582fd0 type: 7
2015-12-30 19:46:49,014 INFO [orbbec.ni.devicestream] destroying oni stream of type: 3
2015-12-30 19:46:49,019 INFO [astra.plugin_service] destroying bin – 3928f0 stream: 1c582a30 type: 3 size: 153628
2015-12-30 19:46:49,026 INFO [astra.plugin_service] destroying stream – handle: 1c582a30 type: 3
2015-12-30 19:46:49,032 INFO [orbbec.ni.device_streamset] closing oni device: \?\usb#vid_2bc5&pid_0403&mi_00#7&e302640&0&0000#{c3b5f022-5a42-1980-1909-ea72095601b1}
2015-12-30 19:46:49,049 INFO [astra.plugin_service] destroying streamset: device/sensor0 393a70
2015-12-30 19:46:49,054 INFO [orbbec.ni.oni_adapter_plugin] shutting down openni
2015-12-30 19:46:49,088 INFO [astra.plugins.xs.XSPlugin] Terminated XS plugin
2015-12-30 19:46:49,092 INFO [context] Astra terminated.
2015-12-30 19:46:49,097 WARN [context] attempt to destroy a non-existent reader: 000000001CE07A70
