Hi. I am currently working with the Astra Mini depth sensor and experimenting with ORB SLAM 2.
ORB SLAM 2 features a settings file called TUM.yaml and it has the following content:
%YAML:1.0
# Camera Parameters. Adjust them!
# Camera calibration and distortion parameters (OpenCV)
Camera.fx: 535.4
Camera.fy: 539.2
Camera.cx: 320.1
Camera.cy: 247.6
Camera.k1: 0.0
Camera.k2: 0.0
Camera.p1: 0.0
Camera.p2: 0.0
Camera.width: 640
Camera.height: 480
# Camera frames per second
Camera.fps: 30.0
# IR projector baseline times fx (aprox.)
Camera.bf: 40.0
# Color order of the images (0: BGR, 1: RGB. It is ignored if images are grayscale)
Camera.RGB: 1
# Close/Far threshold. Baseline times.
ThDepth: 40.0
# Deptmap values factor
DepthMapFactor: 5000.0
Especially I am looking for the intrinsic camera parameters; the focal length (fx, fy) and the optical centers (cx, cy).
I guess I need to calibrate my camera myself in order to get the k1, k2, p1 and p2 parameters; is that correct?
Please could somebody point out the correct settings for the Orbbec Astra Mini depth sensor ?
UPDATE 18th April 2018
I meanwhile followed the calibration procedure contained in the calibration package available here.
Here are the results:
[Left Camera Intrinsic]
578.457 0 346.077
0 571.928 250.389
0 0 1
[Right Camera Intrinsic]
517.723 0 337.738
0 512.275 242.524
0 0 1
[Right to Left Camera Rotate Matrix]
0.999841 -0.00841257 0.0157468
0.00861483 0.999881 -0.0128205
-0.015637 0.0129542 0.999794
[Right to Left Camera Translate]
-24.8819 0.138074 -0.203578
With the help of this tutorial and the depicted matrix, I can extract the fx, fy, cx and cy values for the left and right camera (left camera is the IR camera and right camera is RGB camera).
But how do I have to apply these values to my YAML file? Within the YAML file, there's only 1x {fx, fy, cx, cy} values to be defined:
Camera.fx: 535.4
Camera.fy: 539.2
Camera.cx: 320.1
Camera.cy: 247.6
Camera.k1: 0.0
Camera.k2: 0.0
Camera.p1: 0.0
Camera.p2: 0.0
Shouldn't there be Camera.fx/.fy/.cx/.cy for both cameras?
Moreover, how do I have to extract the k1/k2/p1/p2/p3 parameters from the matrix I got from the calibration process (depicted above) ?
