Problem
I can’t view the Astra Pro RGB feed on OSX. I’ve tried accessing the feed through the SDK (SimpleColorViewer-SFML, SimpleStreamViewer-SFML) and it just shows a black screen. I tried accessing the camera through other applications (skype, facetime, photobooth) with no success. The camera just doesn’t show up as an available input.
The depth streams (SimpleDepthViewer-SFML, etc.) work fine.
System specs
macOS Sierra 10.12.1
Macbook Pro (Early 2013)
cmake 3.6.2
also tested on:
macOS Sierra 10.12
Macbook Pro (Early 2015)
cmake 3.6.1
Tried Solutions
Debug Samples
I compiled the samples using ./build_samples, and later ./build_samples -d. Everything compiles successfully. astra.log has no content on both occasions, even after running some samples.
Other OSX Applications
Some other posters [0, 1] have been able to view the camera in other applications, but I haven’t be able to do that. When I open skype/facetime/photobooth, they all only show the built in camera as the only option.
[0] Problem with RGB camera on Astra Pro
[1] Color Image Not Firing On Frame Event
OpenCV
I tried to access the raw camera feed through OpenCV [2] - no luck. The only available camera is my built in one.
[2] Video capture on MacBook - OpenCV Q&A Forum
OpenNI
This looked promising [3] but the download link is broken that’s listed in that thread. I’m guessing if facetime/skype etc. aren’t recognizing the camera than there’s no reason to believe that OpenNI would be able to access the feed.
[3] Compatibility Astra Pro and OpenNI2 - #3 by josh
Other information
I’ve run ioreg -p IOUSB and the Astra shows up as a USB device. Relevant output lines:
| +-o Astra Pro HD Camera@1a121000 <class AppleUSBDevice, id 0x10000afbb, registered, matched, active, busy 0 (10 ms), retain 16>
| +-o ASTRA Pro@1a122000 <class AppleUSBDevice, id 0x10000afd3, registered, matched, active, busy 0 (15 ms), retain 20>
