I am adapting code from the ColorReaderEvent in the cpp-api folder. Seems pretty straight forward. But the on_frame_ready function is not being called. I am calling initialize() first, starting the color stream and then calling astra_temp_update();
Is there something that I am missing?
The depth stream works properly.
I am able to view the live color stream using an app like Photo Booth
Based upon your comment that you can view the live color stream in Photo Booth, I am guessing that you have an Astra Pro sensor, which exposes the color stream via UVC (like a standard webcam). This is in contrast to Astra and other OpenNI-like cameras which only expose color via an SDK.
See threads like:
for more on the UVC color camera and differences between Astra and Astra Pro.
Also, some sample code about accessing Astra Pro color:
We will be releasing an update to the Astra SDK that supports the Astra Pro color stream through the same API, but we’re trying to get a release of our skeleton tracking done first. See also: [Sticky] Astra SDK resources & updates
