Hi, I am using Femto Bolt to do some video recording using Ubuntu 20.04.06. The Femto Bolt is already installed with the latest firmware release separately on windows. However, I have been encountering some issues with it.
The k4aviewer does not work even after all the header files and dynamic libraries link replacement. There was an error that says " k4aViewer failure: “Failed to initialize audio backend: incompatible device!”. I am using the Azure Kinect Sensor 1.4 and I found this issue reported on github but no solutions yet (k4aViewer failure: "Failed to initialize audio backend: incompatible device!" · Issue #387 · microsoft/Azure-Kinect-Sensor-SDK · GitHub).
Failure of depth engine initialization and also occasional segmentation fault. We have tried power cycling, unplugging and replugging the USB, but it seems that the only solution that resolves this is to reinstall the OrbbecSDK again. Our Orbbec SDK is on version 1.10.8 as we installed it via the Debian Apt Repository. Would the latest release of the SDK (1.10.12) solve this issue?
I would be very appreciative if anyone has any insights in solving the above two issues. Thank you.
